Re: Cub Clutch Adjustment
Posted by gene (missouri) on September 10, 2005 at 21:45:17 from (208.144.172.170):
In Reply to: Cub Clutch Adjustment posted by GNB on September 10, 2005 at 20:42:09:
Early model Cub's clutch pedel adjustment can be made from the bottom of the torque tube. The adjusting yoke is inside the torque tube. Loosen the adjusting nut, remove the pin from the yoke and turn the yoke out until you get the correct pedel free travel. Reinstall the yoke and pin, tighten the nut.
Gene (Missouri)
Post a Followup
