Re: Farmall H compression psi?
Posted by El Toro on September 11, 2005 at 07:39:38 from (205.188.117.73):
In Reply to: Farmall H compression psi? posted by John in Ct on September 11, 2005 at 06:46:30:
My manual doesn't list that cylinder compression,
but I think your engine should be from 90 to 100psi. The main thing to do is to compare your
readings. They should be within 10-15lbs of one another. If three cylinders read 95 and one reads 45 isn't too good or if three read 95 and one reads 145 is usually a carbon buildup on this cylinder. Take your compression test and see what you have and if it looks odd, post it on here. Hal
Post a Followup
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
