Re: gasline filter farmall h
Posted by Dave in CT on September 11, 2005 at 11:17:57 from (69.182.79.162):
In Reply to: gasline filter farmall h posted by lekander883 on September 11, 2005 at 06:07:48:
After seeing how much fine rust had gotten past the intact sediment bowl screen (built up in the carb screen) on my H, I put one of those clear cylinder inline filters for 5/16" lines from NAPA (NAPA #: 730-9561) . It's got a changeable filter element. That way I can just look to see if there's anything building up (2+ years, so far nothing). You could also use one of those clear plastic disposable filters but check the flow rating - make sure it's not made for fuel pump systems.
Post a Followup
