Re: finally finished 1939 F-20 pic
Posted by Ron in Nebr on September 11, 2005 at 23:14:51 from (65.172.143.82):
In Reply to: Re: finally finished 1939 F-20 pic posted by Paul G. in Mn on September 11, 2005 at 19:33:04:
Not just "help you turn" but even more...it'll apply the brake to the inside(of the turn) rear wheel and lock it up completely if you turn far enough allowing you to turn the tractor as short as possible- the inside rear wheel's locked up and it spins around it and the narrow front wheels will be turned far enough that it will just pivot in a complete circle around the locked up rear wheel...you can do a complete 180 and drive the inside rear tire back out on it's own tracks.
Post a Followup
