Re: Belly pump help needed -- '51 M
Posted by farmallhal on September 12, 2005 at 16:14:53 from (64.24.35.16):
In Reply to: Belly pump help needed -- '51 M posted by billOH on September 12, 2005 at 15:01:39:
Bill, you are missing quite a few parts but they should all be easy to find. The fill pipe on top should be a piece of pipe 3/4" dia. by 3 1/4" long. You also need the vented cap you mentioned. Orginally it also came with a dip stick but rarely seen on many tractors after 50+ years. One could be made from a stiff piece of wire if desired with a couple of scribe lines to indicate full and a quart low. The three outlets on the sides are welded fittings from 1/2" pipe nipples and 90 deg. elbows. They are all the same according to the parts catalog. In addition to these fitting parts all torque tube penetrations also have a felt dust seal, a steel washer and a spring to cover up the balance of the opening from dust and dirt. The control rod opening also needs the same items. The fill and control rod openings need a larger size then the outlets. I would suggest the Nebraska Cowman who is a regular on this forum for the fitting parts. His email is howster@nebnet.net. The dust cover pieces I noted can be obtained from Ron Berlage at Pilot Knob Restorations as they are listed in his catalog. Ron can be reached at (815) 777-0826. They are not available at CaseIH. You can determine any hydraulic hoses you need and obtain them locally at a tractor supply type facility as they generally always make custom hydraulic hoses. From reading other posts on this forum, I would suggest you not operate the system with it capped and without hoses. It seems without some relief somewhere in the system you are prone to blow gaskets and start leaks if operated with the caps in place and not hooked up to something which can absorb the pressure. Hope this helps and have fun. Hal
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
