Re: Kind/Brand of Primer to use after Phosphoric A
Posted by CNKS on September 13, 2005 at 07:12:02 from (204.249.178.138):
In Reply to: Kind/Brand of Primer to use after Phosphoric Acid posted by Dave in CT on September 13, 2005 at 07:00:03:
What I usually do with such products is use a scotchbrite pad, or similar product and remove as much of the residue as possible. I then treat with wax and grease remover -- I use PPG DX330. I also use PPG Omni MP 170 epoxy primer. Whatever you do don't use etch primer after a phosphoric acid treatment -- there is the possibility of too much acid. I have not yet painted over "Must for Rust", although there are some parts ready to paint. Thus far I have only used Picklex 20, I don't think there is much difference except for cost, but I don't know the formulations -- My guess is you will be fine. As far as breaking up the finish, if you paint it within a reasonable amount of time after scuffing or sanding, it shouldn't be a problem, as the epoxy seals the metal and prevents moisture from getting in. That is one advantage of epoxy primers, they are waterproof, other primers aren't.
Post a Followup
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
