Re: I need help again on Model 240
Posted by Hugh MacKay on September 15, 2005 at 03:28:46 from (216.208.58.177):
In Reply to: I need help again on Model 240 posted by Dan Dresser on September 14, 2005 at 14:13:59:
Dan: Usually there is not a whole lot wrong with these. Spring and thrust bearing are usually the culpert. Ocasionally bushings in the throttle shaft. Governor can be removed without disturbing distributor, you will skin a few knuckles, perhaps utter a few choice words. Some recomend removing rad, that will make it easy. I quite often loosen rad, unbolt at top to let top tip foreward. Depending on tractor model, you may get off just removing shroud around fan.
Post a Followup
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
