Re: Pipe plug in engine oil pump/oil pressure?
Posted by Slappy on September 15, 2005 at 05:35:34 from (143.88.85.82):
In Reply to: Pipe plug in engine oil pump/oil pressure? posted by leon on September 15, 2005 at 03:22:38:
I don't know much about the C tractors, but none of my tractors (all IH) have adjustable oil pressure at the pump - only a spring loaded relief valve. Oil pump covers can get warped, blow out the gasket, or "gouged" by the gears, all of which can result in low oil pressure. The fix is to have the cover machined flat (or use a sheet of plate glass with some grinding compound and do it the hard way), replace the gasket, and be sure to measure the end play in the shaft and add another gasket if you need to to prevent further gear contact with the plate - remember to order the gaskets, don't just make one from whatever's handy, thickness is important here. The gear lash should also be measured and if too far out of spec they can be replaced. They are pricey, however, and in some cases it is almost as cheap to by a new oil pump as to replace both gears. Many people I know have replaced only the body gear (the one that isn't pinned to the shaft), and while not within spec, enough backlash was made up to restore respectable oil pressure. If you get no satisfaction with these fixes, then you should consider main, rod, and/or cam bearing problems. Again, I've never been inside a C, but if they are similar to A's, H's and M's these fixes will help.
Home
| Forums
Today's Featured Article -
Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
