Re: 350 Utility Light Switch
Posted by chadd on September 15, 2005 at 09:04:03 from (155.92.30.139):
In Reply to: 350 Utility Light Switch posted by Jeff in Cincinnati on September 15, 2005 at 08:23:39:
Like you said, the first position is off, the next position to the right is supposed to be the low beam setting, and the last position is supposed to be the high beam setting. The rear light should always stay on. There should be a coil of wire on the back of the light switch to lessen the voltage going to the lights. If that were replaced with a straight wire, there would be two high beam settings.
Post a Followup
