Re: F-20 Rear Axle
Posted by Walt in Jaxn Tn. on September 16, 2005 at 22:27:30 from (24.176.117.211):
In Reply to: F-20 Rear Axle posted by Dave S on September 16, 2005 at 20:34:02:
There are two, one to keep the grease in the transmission/rearend in it's place and one behind the brake assembly to keep the grease in the bull gear housing in it's place. The one behind the wheel hub is to keep dust out of the outer cage bearing. I'd remove the fill (over flow) plug on the side of the bull gear housing (not the drain plug on the bottom) and let the grease flow down a clean path into a clean container till it stops and put it back in the transmission. You will find that when you keep the bull gear housings from over filling, you will not have as much problem with grease leaking out the axel shaft seal, also, give the zerke fitting in the middle of the wheel (on the out side) a couple shots of gun grease from time to time, that is what lubricates the cage bearing.
--Walt--
Post a Followup
