Thrust bearing on steering shaft for an H
Posted by muley on September 17, 2005 at 08:25:14 from (64.12.117.13):
Which way does the steering shaft thrust bearing go on a 1945 H? Wider surface facing up or down? Thanks.
Post a Followup
