Re: electrical charging question on '41 H
Posted by 55 50 on September 17, 2005 at 17:29:26 from (216.114.212.67):
In Reply to: electrical charging question on '41 H posted by awutay on September 17, 2005 at 15:34:40:
I've worked on a friend's "H" that had a similar problem. The cutout was bad. Do you have a cutout or a regulator?
Post a Followup
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
