Re: 6-volt generator
Posted by P Backus on September 17, 2005 at 18:25:55 from (69.128.32.135):
In Reply to: 6-volt generator posted by baler 46 on September 17, 2005 at 16:59:13:
Could it be that one of your generators is for and H andthe other
for an M or something similar? The size of the pulley would have
a relationship to the size of the crankshaft pulley driving it. I
don"t know for sure, but it could be that an M pulley is a bit
bigger.
Do you have the 4 position light switch or the 3 position light
switch? The thing you called a relay box on top of the generator
is probably a cutout, used on the older style generators. The
newer ones had a voltage regulator mounted elsewhere (by the
steering column). I"m not sure of this either, but I think that by
"50 they were using the regulator with the 3 position switch. The
4 pos switch was used with the cutout style.
Paul
Post a Followup
