Re: Hydraulics on a 340
Posted by K.B.-826 on September 17, 2005 at 19:11:40 from (209.163.30.17):
In Reply to: Hydraulics on a 340 posted by Wayne Johnson on September 17, 2005 at 13:17:43:
Your unloading valve (regulator/saftey valve in IH terms) is stuck. Should be located in the valve bank under the dash. It will be the one with no linkage attached to it. Should be able to repair it without removing it from the tractor. It has an end cover held on by four bolts. Remove the end cover, but be careful in doing so, as it has heavy springs pushing against it. Remove two bolts in opposite corners first, replace them with bolts that are at least an inch longer, then start loosening the other two bolts. Once you get the cover off, pull the two pistons out, polish them and their bores with fine emery cloth, clean with diesel fuel, and replace the o-ring on the piston. Kind of in between the two piston bores, you'll see what looks like a flat headed screw, screw it out. This is the orifice screen. If it is collapsed or dirty or otherwise damaged, get a new one from your Case-IH dealer. Replace the cover gasket and you should be in business.
Home
| Forums
Today's Featured Article -
Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
