Re: Firing order
Posted by El Toro on September 18, 2005 at 08:34:53 from (205.188.117.73):
In Reply to: Firing order posted by Double C on September 17, 2005 at 15:33:11:
You can bump the starter and see which way the rotor turns, then use the firing order below depending on your rotor rotation. Hal
CW
2-1
4-3
CCW
1-2
3-4
Post a Followup
