Re: Belly pump help needed -- '51 M
Posted by farmallhal on September 18, 2005 at 16:47:16 from (64.24.35.16):
In Reply to: Belly pump help needed -- '51 M posted by billOH on September 12, 2005 at 15:01:39:
Bill, In case you weren't able to find the hydraulic cap and dip stick I just saw a set on EBay, Item 7546651782. It list the p/n for the cap as 5047E which is the correct cap for a M but doesn't list the dip stick part no. The correct dip stick part no. s/b 15158E with a possible additional alpha character at the end.
Also, I looked in my M owners manual and the pump capacity is 6 quarts. It should be filled with everything in the lowered or "relaxed" position. If you overfilled it you might want to drain out anything over 6 quarts.
Hope this helps and maybe you had a successful trip to the salvage yard for the needed items. Good luck. Hal
Post a Followup
