F-20 Update - Sleeve Question
Posted by Tony (A2, MI) on September 19, 2005 at 08:12:01 from (64.199.1.202):
After pretty much a 18 month hiatus, I am working on my F-20 Narrow again. I have put an update up on my Restoration Story site at:
http://www.oldengine.org/members/pitts/mbf/F20NRestoration.htm
Newest update at:
http://www.oldengine.org/members/pitts/mbf/F20NRestoration%20Page%204.htm
Now for my sleeve question. Today I attempted to hone my sleeves and I found that one may be beyond repair. This is the cylinder that was most corroded as you can see here (These are LARGE files, smaller versions are here (http://pg.photos.yahoo.com/ph/apittsworldnetattnet/album?.dir=989a):
http://us.f1.yahoofs.com/bc/641a983d_m4187e210/bc/F-20N/Farmall+F-20N+May+19+2003+035.jpg?BCHHgLDByQ_rpPPv
After getting it loosened up, the piston out, and honing it looks like this. You can still see some corrosion, and you can see a couple small divots in the sleeve wall.
http://us.f1.yahoofs.com/bc/641a983d_m4187e210/bc/F-20N/Sleeves+005.jpg?BCHHgLDBAm5vaMKX
http://us.f1.yahoofs.com/bc/641a983d_m4187e210/bc/F-20N/Sleeves+004.jpg?BCHHgLDB7SRIV.zo
Is this sleeve unusable? If so, would I then want to replace all 4? Any other comments are welcome as well.
I"ll have these photos up on my site soon as well. I also just noticed I have some link problems on page one of the story that I will fix as well.
Thanks a lot for your help,
Tony
Tony Pitts
Ann Arbor, MI
Hudson Mills Old Power Club
14th Annual Show June 3-5, 2005
Dexter, MI
http://www.hudsonmills.org
Post a Followup
