Re: Cant get rear rims on wheel right !!!
Posted by old on September 19, 2005 at 18:19:16 from (207.69.139.158):
In Reply to: Cant get rear rims on wheel right !!! posted by J Muehring on September 19, 2005 at 18:00:27:
Heres an old truckers trick. You need an impact gun to start with. Jack the wheel up till it spins free. Then lay a block next to the tire and loosen all the clamps a little. Now turn the tire and every place it hits or get near the block tighten up that place a little and just keep going around a few times till its right. You need the block tall enough to get a good look at whats happening and you may need to push it up to the tire a few time.
Post a Followup
