Re: Cant get rear rims on wheel right !!!
Posted by K.B.-826 on September 19, 2005 at 19:09:36 from (68.115.103.185):
In Reply to: Cant get rear rims on wheel right !!! posted by J Muehring on September 19, 2005 at 18:00:27:
old's got it exactly right. Jack it up and loosen and tighten the rim-to-wheel bolts until the tire is no more than 1/4" away from the block at any point. It takes a little work but it can be done.
Post a Followup
