Re: super m 1952
Posted by captaink on September 20, 2005 at 06:55:56 from (66.115.214.56):
In Reply to: Re: super m 1952 posted by Janicholson on September 16, 2005 at 09:35:21:
The engine that I did was a D282 from a 560 Diesel. The machine shop used a sealer behind the thin sleeve that was inserted. I did this about 24 years ago on two cylinders in the block. Since then I have put over 4000 hours on the engine and just had the head off to replace a head gasket. There were no cracks in the cylinders (I especially checked for them) and I'm getting no water in the oil.
You have some good points that I agree with and nothing wrong with your advice. I just wanted to point out that this repair is sound and does produce lasting results in the real world if done properly.
Post a Followup
