Re: 350 Utility Oil Leak
Posted by PAULIH300 on September 20, 2005 at 17:37:22 from (152.163.101.13):
In Reply to: 350 Utility Oil Leak posted by Jeff in Cincinnati on September 20, 2005 at 17:33:22:
That sounds like its coming from the clutch housing which would mean the trans/TA input seal is leaking.The trans uses Hy Tran with TA,so its not going to look like 80/90 gear lube.
Post a Followup
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
