Re: 350U will not run
Posted by Mark and Anik on September 21, 2005 at 20:36:24 from (216.86.96.83):
In Reply to: Re: 350U will not run posted by El Toro on September 19, 2005 at 18:45:57:
Ignition parts are all new. I pulled off the hydraulic pump and peered in. No teeth on the timing gear. I guess I know what is wrong now. Anybody know where I can get a set of gears for this tractor?
Post a Followup
