Re: F-20 Rear Axle
Posted by wes in PA on September 21, 2005 at 20:50:53 from (205.174.100.158):
In Reply to: F-20 Rear Axle posted by Dave S on September 16, 2005 at 20:34:02:
I replaced the felt washers in mine and they still leaked so i took them back apart and did some investigating. I found a drain hole in the back of the housing behind the cage bearing that was plugged with hardened grease. This was causing the oil to build up in there and leak out past the felts. I removed the clog and now I have no oil leaking from my hubs. I guess someone put too much grease in the fitting on the hub.
Post a Followup
