Super A rings and sleeves
Posted by Kenr8251 on September 22, 2005 at 01:52:26 from (128.227.163.110):
Bought a sleeve and ring set through the local NAPA dealer. Went with the 3 1/8 bore. Everything went well, built a sleeve puller and got the old sleeves out and the new ones installed. When I put the rings on the new aluminum pistons found the oil scrapers would just fall through the sleeve. Not only are they way too small for the 3 1/8 bore sleeves, they are too big to fit the old 3 inch bore iron pistons.
All four sets are the same. Like they are maybe .010 or .015 over not .125.
Anyone seen this?
Post a Followup
