Re: Farmall A Heavy Wheel
Posted by Stan(PA) on September 22, 2005 at 08:34:00 from (69.166.61.166):
In Reply to: Re: Farmall A Heavy Wheel posted by Cityboy-McCoy on September 22, 2005 at 08:10:04:
I agree with George. Logic says it was a whole lot CHEAPER to put a stamped wheel on the left. The cast right wheel is to help offset the weight of the engine on the left. Left wheel would be the pivot point of a roll, and the weight of the left wheel wouldn"t have much effect on the roll point. Of course, I could be wrong, happens pretty regular....Stan
Post a Followup
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
