Re: Farmall A Heavy Wheel
Posted by Cityboy-McCoy on September 22, 2005 at 15:27:41 from (65.0.150.173):
In Reply to: Re: Farmall A Heavy Wheel posted by George Willer on September 22, 2005 at 14:24:45:
I did read what you wrote. And I still, respectfully, disagree with it. A light wheel on the left and a heavy wheel on the right helps shift the tractor's center of gravity more towards right; two identical heavy-weight wheels make no contribution toward shifiting the center of gravity at all, leaving it up to the rest of the tractor, which is offset.
As for operator weight, hey, how did you know I was a scrawny, 380 lb weakling?
mike
Post a Followup
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
