Re: tight valve on a H
Posted by Janicholson on September 22, 2005 at 16:37:16 from (66.173.50.166):
In Reply to: tight valve on a H posted by melvin on September 22, 2005 at 15:49:52:
There are only two possible problems (assuming the engine was running before repair, and not stuck. And that you have measured the installed height of the valves, and this one is higher than the rest.
1} The valve in that hole was ground more than allowed, causing it to end up shorter (deeper) in the head. Your fault for not comparing the valves on assembly, an your nickel.
2} The other possible grief is that the valve seat was machined/ground too deep alowing the acceptable valve to set too deep in the head. This is the probable cause. It is not acceptable to get this poor workmanship (at least without warning) from the shop. The fix (if you decide to do it) is to have at least one hardened valve seat installed. (I'd have them all done, with the shop picking up a chunk of the cost. If it had been done correctly, you would not be into the engine now.
Repair?!?!?
Look at the valve stem where it comes out of the retainer, If there is 1/16" or so sticking up, I would grind the tip of the valve (die grinder or dremel with much cloth to catch grinding dust). Maintain the flatness and take your time. Remove only enough to get the adjustment, plus .005".
This valve will be shrouded by the material around the deep seat to some degree, and thus not flow as well as normal. It will probably provide fair service, but not ultimate power.
Good luck and let us know what the outcome is.
JimN
Post a Followup
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only ... [Read Article]
