Re: F-20 Clutch
Posted by Janicholson on September 22, 2005 at 16:55:02 from (66.173.50.166):
In Reply to: Re: F-20 Clutch posted by Corndude on September 22, 2005 at 04:42:05:
Check the splines on the clutch shaft for rust burrs or worn spots. If the shaft wears into the splines it can push up against the fly wheel and spin up the gears. Excess grease, oil from bad seals, or pilot bearing, can and often does make sticky residue. Cleaning might work for awhile, but most will have saturation into the fibers and repeat the issue. If I must fix them, I heat them (outside not indoors) to roasting with an industrial heat gun (air/electric) moving uniformly all around till no more material boils out either side.
It works. JimN
Post a Followup
Today's Featured Article - Talk of the Town: Winterizing Engines - To Drain or Not to Drain? - by Russ Berry. What is this strange attraction I have to equipment and machinery? How did I get this way? I came from the suburbs and own a small horse farm in rural Loudoun County, Virginia. You can call me a "weekend farmer." The local farmers do. Does it bother me? No. I am just happy to have their friendship. At least the word "farmer" is in my title. But what is the attraction? How can I explain the sensation and exhilaration I feel when I turn the key and hear the engine come to life (most ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
