Re: FARMALL 340 T/A Problem
Posted by K.B.-826 on September 23, 2005 at 20:02:04 from (68.115.103.185):
In Reply to: FARMALL 340 T/A Problem posted by Cheryl on September 23, 2005 at 18:16:02:
Easy fix, your clutch pedal and TA linkages are out of adjustment. I won't bore you with the details of what's actually happening inside of the TA that causes this problem when the linkages get out of adjustment, unless you REALLY want to know. A $25 I&T manual will show you a detailed adjustment procedure, it's a little hard to explain without the diagrams in front of you. Follow the directions to the letter, this is a very particular adjustment.
Post a Followup
