Re: 560 Moisture build-up
Posted by captaink on September 24, 2005 at 21:13:54 from (64.33.250.37):
In Reply to: 560 Moisture build-up posted by beefalonut on September 24, 2005 at 17:05:46:
I’m guessing that you are seeing this on cooler mornings or evenings in humid conditions under light or no-load conditions. If so, what you are seeing is the cooling of the carburetor from the “venturi” effect. As the air passes through the venturi in the carburetor it speeds up, and absorbs heat from the surrounding metal. This lowers the temperature of the carburetor and adjacent intake manifold, which in turn condenses water from the air next to it (similar to a cold beer can on a hot humid day). In severe cases with temperatures below 40 degrees F, frost will form also.
Post a Followup
