Re: IH Super C Electrical Woes
Posted by El Toro on September 25, 2005 at 04:06:52 from (205.188.117.73):
In Reply to: IH Super C Electrical Woes posted by Tom Yaz on September 24, 2005 at 17:35:57:
That is good advice from Paul on checking the rotor for rotation could be a stripped gear. Here's a step by step for troubleshooting for no spark: Be sure distributor cap is dry & clean. 1. Is there battery voltage at the coil? Use test lite or volt meter. 2. Is there battery voltage at the points? Use test lite or volt meter. 3. Remove distr. cap, rotor & points cover; remove coil wire from distr. cap & hold within 1/4" of a good ground. 4. With points closed and ignition switch on, snap the points open and closed a few times & check for spark at the coil wire end. 5. No spark: may have dirty or burnt points, bad condenser or coil. Coil wire must be attached to + on coil if battery is + grounded. If this tractor has been converted to 12 volts and uses a ballast resistor they are known to cause problems. One last thing is to check for voltage at your ignition switch. Check for input voltage to the switch and with the switch on check the output side for voltage. If you have voltage on the input side only, use a clip lead and jump past the ignition switch and see if the engine will start. Hal
Home
| Forums
Today's Featured Article -
Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
