Re: 504 utility steering arm
Posted by Janicholson on September 25, 2005 at 08:55:06 from (66.173.50.141):
In Reply to: Re: 504 utility steering arm posted by Nebraska Cowman on September 24, 2005 at 16:44:32:
Welding both sides will help hold it straight on the shaft, however it may ruin the seal on the shaft. If power steering, the leak could be tremendous. Protect the seal from spatter and heat by making a two part shield from tin, and welding short 10 second passes with cooling between with wet rags.
JimN
Post a Followup
