Re: 1959 cub engine seized
Posted by El Toro on September 25, 2005 at 12:06:26 from (64.12.117.13):
In Reply to: 1959 cub engine seized posted by Jimmy Freeman on September 25, 2005 at 09:00:50:
Pour transmission fluid into each cylinder and let it soak for a few days. With the plugs out just bump the starter to see if the engine moves.
You need to be patient it just may be surface rust in the cylinders. It's a good idea to squirt engine oil into the cylinders whenever an engine is stored for any length of time and then crank the engine a few revolutions and either drain the fuel system or add a fuel stabilizer to
stop that gummy buildup in the fuel system. Hal
PS: The Cub engine has a history of losing their oil pressure. If you get it started watch your
oil gauge.
Post a Followup
Today's Featured Article - Harry Ferguson - The Man & The Machine Harry Ferguson was christened Henry George but every one called him Harry. Harry was born in a small Irish town called Growell in County Down about 16 miles from Belfast. Harry Ferguson led a varied and colorful childhood causing mischief where ever he could. He showed mechanical aptitude at a very early stage in life and showed no inclination towards ... [Read Article]
