Re: Splitting Farmall 100
Posted by couv on April 07, 2009 at 17:16:10 from (98.194.48.149):
In Reply to: Splitting Farmall 100 posted by Nick D on April 07, 2009 at 08:56:32:
I blocked mine with a single wooden block, on end. The block is about 12 " x 12", like a sill. To make sure the disconnected rear of the tractor didn't move, I used the front cultivator pieces wedged against the front of rear tires, and then strapped in place with a winch-up strap around each tire, and a block behind each rear tire.
ALSO BE CAREFUL --- when you disconnect the front axle, it is very heavy, and falls real real fast ! I had some dumb luck and didn't break a wrist or a hand when it fell.
I used the swing frame and a chain hoist from then on in the process
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
