Re: More questions on non-charging 460 Utility....
Posted by old on September 26, 2005 at 19:08:32 from (207.69.137.8):
In Reply to: More questions on non-charging 460 Utility....... posted by Capt. Minx on September 26, 2005 at 18:15:06:
Do you have to jump start it or does it start with that battery?? If you are jump starting it then you have 2 problems I think. One is bad battery and the other is your chargeing system isn't working right. You may also have a short some where which is killing your power. A good battery with a good charge will run a tractor for hours.
Post a Followup
