'53 Super A Wiring Diagram / Issues
Posted by Randy Black on September 26, 2005 at 20:12:26 from (69.55.159.86):
Does anyone have a wiring diagram for a '53 Super A? I recently replaced the original cloth-jacketed wiring harness with new wiring. The problem that I am having is that the on/off switch does kill the ignition. I have to pull the wire to the coil to shut it off. The switch seems to control the battery charge however. Any ideas?
Post a Followup
