Re: Dewatering tires
Posted by Jim Allen on September 27, 2005 at 05:53:29 from (209.173.160.22):
In Reply to: Dewatering tires posted by HAS on September 26, 2005 at 19:53:02:
You could also run over part of an old
plowshare, stab it 6-inches into your tire, let all
the chloride drain into your field and create a
dead spot that nothing will grow in for a
season. Seriously, with the other tire, I used
the hose method outlined in the other post. I
now just use iron because I can move it on or
off as needed.
Post a Followup
