Re: Low Farmall B Oil Pressure
Posted by captaink on September 27, 2005 at 07:59:12 from (66.115.214.56):
In Reply to: Low Farmall B Oil Pressure posted by Leon W on September 27, 2005 at 07:55:24:
I would check to verify that the guage is accurate before tearing into it. If it is, pull the pan and check the oil pump to make sure that the plate on the bottom is flat and the gasket is not blown out. After that it's bearings, etc. Low oil pressure is not desirable, I'd check into the reason why and correct it. My 2 cents...
Post a Followup
