Re: engine running backwards?
Posted by El Toro on September 28, 2005 at 04:47:32 from (152.163.101.13):
In Reply to: engine running backwards? posted by Dave in MN on September 27, 2005 at 20:10:22:
You would need to bring No1 piston up to TDC on the compression stroke. You would also need to watch which way the rotor turns. If the rotor turns CW you would install your wires like this:
2-1
4-3 or if it turns CCW you install the plug wires like this:
1-2
3-4 and you set the rotor on No1 on the distributor and install it in the tractor. Hal
Post a Followup
