Re: 240 U starter-how many fields
Posted by Billy McCarver on September 29, 2005 at 00:33:03 from (136.182.2.221):
In Reply to: 240 U starter-how many fields posted by Al L. in Wisc. on September 19, 2005 at 17:04:59:
Most 6Volt starters only have two fields. At best, they would barely turn over fast enough to start the engine. Is your tractor 6V or 12V. If it is still 6v, check the size of your cables, they should be at least as big around as your finger. Generally #2 or larger. 2-0 welding cable works well. Any dirt, corrosion, burned wires will build up resistance in the starter circuit. It doesn't take much. Most tractors had the ground cable from the battery connected directly to one of the mounting bolts of the starter or nearby. Also check the field windings where they come together at the post. My grandfather used to crank on the nut to tighten the connection and would twist the post and break it loose from one or both windings. One field winding and it would turn too slow to start on 6v. Both broken loose and nothing turned. One way to check would to jumper 12V to the post. If the starter turns fast enough to start the tractor then one field winding is loose. Also check the brushes and commutator for dirt. Good luck with this. Billy
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
