Re: Farmall A cylinders
Posted by El Toro on September 29, 2005 at 08:59:04 from (152.163.101.13):
In Reply to: Re: Farmall A cylinders posted by jnewark on September 29, 2005 at 08:26:11:
Now I know where to get one made, just kidding.
In think my manual tells you fill the block and check for leaks. Just enough to cover the seals would be enough. Hal
Post a Followup
