Re: 300u jumpy clutch
Posted by C Davis on September 29, 2005 at 15:58:53 from (209.9.212.184):
In Reply to: 300u jumpy clutch posted by TRF Jim on September 29, 2005 at 15:28:36:
Not being smart but are you sure it is the clutch? I believe you are steping on the peddle insted of pushing like on a row crop if the throttle is to high and you bounce one time your foot continues to bounce the clutch? the other possiability is the return spring on the peddle is to tight or too loose. just my thoughts for the simpilest possiable fix.
Post a Followup
