Re: 300u jumpy clutch
Posted by the tractor vet on September 29, 2005 at 16:24:31 from (4.124.87.148):
In Reply to: 300u jumpy clutch posted by TRF Jim on September 29, 2005 at 15:28:36:
There are alot of things that can cause this and none of the fixes are simpel , (1) someone may have installed a ceramic disc and not ground the flywheel . (2) broken damper springs in the disc. (3) warped pressure plate (4) the pressure plate is not set correctly . With out splitting the tractor and removing the clutch and disc. and looking at everything it is real hard to say . If the rear main seal is leaking and ya have oil on the disc this will cause it to grab . Hard spots in the flywheel can cause it .
Post a Followup
