Re: Bob M
Posted by Chad from Michigan on September 30, 2005 at 04:56:53 from (152.72.173.130):
In Reply to: Bob M posted by Gary_N_WV on September 29, 2005 at 18:18:13:
What ever you do don't use a easy out! Don't Do it! I broke off the idle tube on my cub carb and then I went to the shop at work and I tried the easy out and gues what broke it clean off. I had one hell of a time getting it out.had to use a drummel and a pic and messed up the surface of the carb where it screws in. I got the easy-out out and then drilled the threads out then re-taped. I bought the new idle tube from Case IH it was $14.00 I was a #4-48 thread.
Post a Followup
