Re: H Manifold Replacement - Advice
Posted by Scott Swanson on September 30, 2005 at 10:54:25 from (24.118.111.240):
In Reply to: H Manifold Replacement - Advice posted by ChrisL on September 30, 2005 at 09:44:44:
Replace the muffler while you are at it and put a rain flapper cap on it to keep out rain. Use anti-Seize compound on the studs before the big socket tightening. Use a new gasket whenever you remove that cast iron spider.
Tighten the studs from the inside out in a pattern. Make sure the gas manifold is clean and tip it upside down and tap it on the concrete floor to make sure no loose rust is hiding in there. You may need to readjust the carb.
Post a Followup
