Re: Super H Carb help
Posted by GordoSD on September 30, 2005 at 15:50:37 from (64.68.166.234):
In Reply to: Super H Carb help posted by Gary_N_WV on September 29, 2005 at 15:21:55:
That brass piece is the metering jet. There is one packaged in the 35 dollar kit, tisco number C510HV sold at my IH dealers.
To remove a non broken one turn ccw. To remove broken off jet, use increasing diameter wire size bits until you just leave alittle brass in the threads, and pick that out. Real asy touch starting the new jet.
Also available at dealer is float (25$), strainer and inlet fitting (13$),
Almost everything else is in that 35 dollar kit.
Post a Followup
