Re: Help H starter button sparks
Posted by jimmorlan on September 30, 2005 at 17:52:39 from (71.97.199.231):
In Reply to: Help H starter button sparks posted by IHCarl66 on September 29, 2005 at 18:37:05:
Had the same problem. After checking it out, I found that the terminal on the Starter cable was touching the housing around the switch. When I pushed on the switch button it would short the battery to positive ground and shoot sparks out what I thought was the swicth. I simply loosened the nut and readjusted the cable and now it is fine.
Post a Followup
