Farmall Tractors Discussion Board
Bent Drawbar...
Posted by T'other Fred on December 25, 1999 at 13:24:55 from (206.72.4.39):
I thought the upward bent drawbar was real interesting. With a little mental application one can do unusual things with a piece of steel.
My Super C drawbar is bent to the left. I thought at first maybe it was the result of serious strain while turning left, with a pin holding the bar centered on the cross member but the bend is just about centered between the pivot and the cross member, not where the pin would act as a fulcrum. I've about decided it was off the tractor when something happened to it.
Fred
Post A Followup
: Re: Bent Drawbar...
