Cub Hood Assembly, CUB Problems and Value
Posted by Retcol on October 01, 2005 at 14:42:08 from (64.33.136.58):
Where can I buy a hood and fuel tank assembly for an early model Cub? I looked at a tractor today that had a section of the hood cut out. I would be interested in buying the tractor if I knew where I could buy the assembly with a reasonable cost. Also, is there anything in particular that I should be looking at on the CUB that is normally a problem area? The engine has been overhauled and it really ran good. What is an early model CUB worth?
Post a Followup
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
