Re: c113 (or late C-123)engine boring
Posted by Charles McNelly III on October 02, 2005 at 18:40:02 from (65.150.21.52):
In Reply to: Re: c113 (or late C-123)engine boring posted by Stan(VA). on October 02, 2005 at 18:22:13:
Thanks for your input Stan. How long has it been since you installed the thinner o-rings? How much did the machine shop charge to cut out the holes in the block? By chance do you know the difference between stepped head pistons and fire flow pistons? YT didn't know.
Post a Followup
